Hole in Basement Floor
Help!
We have just removed a rug from a basement room, and discovered a loose fitting metal sheet covering a 10 inch deep square hole about 15 inches around. We dug and could not find any pipes or anything except rotten wood frame surrounding the hole. Inside this hole is only dirt.
Question, what would the hole be for? and should we fill it up with cement and then put the new rug on it?
thanks,
Charlie
thanks,
Charlie
Hi,
I will dig deeper to check for pipes, however when I did before I could not find pipes. Our neighbour looked at it and thinks it was a safe in the floor by the way the cement is broken around the edges, he thinks it was pulled out?
thanks
Charlie
thanks
Charlie
Hole in basement floor
When I was reading your post, my first thought was buried treasure. You friend may well be correct about the infloor safe. You could simply replace the metal plate and place your own time capsule in the hole.
