Efflorescence on Basement Walls
Old 10-08-01, 02:14 AM
A
Question
I have a 65 yr old poured concrete basement with no cracks in the floor or walls, and there is never seepage of water.
My problem is that there is a powdery white substance in several areas on the basement walls which, when you scrape it away, some of the concrete beneath crumbles away as well. This is only on the basement walls, not on the floor. It is happening in places here and there on all four walls. I have been told this is happening because of lime in the concrete. There are no trees or shrubs growing up against the house.
I plan to be in the house 5 yrs or less--is there anything I can do to the walls to repair them? I do not plan to finish the basement--I only want to paint the walls and floor.
Thanks for any helpful hints.
Old 10-08-01, 03:10 PM
T
Received 1 Upvote on 1 Post
Sealing basement walls
You could seal the walls with a couple coats of masonry sealer.
Old 10-09-01, 01:55 AM
A
Question another ?
Would this solve my problem? Or would that also start to crumble after a while?
Old 10-09-01, 03:40 PM
Insulman
Try contacting someone in your area that supplies masonary cleaners... There are various products out there that will clean and seal masonary walls.
A local brick supplier should be able help you find out where to locate the correct products...
Sure Clean is one company I know which makes masonry cleaners.
Good luck
Jim
