h2o in basement
35 y.o. home with h2o comming in around perimeter of basement where block wall and cement floor meet. Exterior correction of problem has been estimated to range from $6000-10000. Do I have any options to correct problem from inside? Considered drylocking walls. However, some walls already have been painted. Unsure if drylock will work effectively since paint is chipping in areas. Also considered renting cement cutter to create a 3-4" deep trench around perimeter which would lead to already existing sump pump designed for laundry hook up. $ an issue. Mess and labor not an issue if option #2 is a possibility.
NO ADVERTISING IN FORUMS
XXXXMESSAGE DELETEDXXXX
Forum topics are not to be used as public bulletin board for free posting of ads, solicitations or advertisements of any kind. When forum posts repeatedly promote a product without discussion and advice to a DIYer, it is also considered advertising.
Forum intent is an exchange of helpful problem solving methods and solutions to questions and not public advertisement.
Inappropriate postings not relevent to the intent of the web site or any postings deemed as such by the host, administrator or moderators will be edited and/or deleted.
Policy applies to ALL forums on the web site. No exceptions.
Direct your advertisements to advertisement department. Use "receive advertising info" link provided below.
If you object to policy, contact the Administrator and state your objection.
The "Contact Us" link is provided below.
Failure to comply will result in your being banned from the website.
Web Site Host & Moderator
twelvepole
twelvepole
only long term solution is outside
The only long term solution to a dry basement is done from the outside. Any waterproofing done to the inside is temporary at best. The drylock will work for a while but it to will fail in a few years. How long it lasts depends in part on how the pressure and volume of the water.
Channeling the water is one way to deal with it. You assume the basement will leak so you accept the water but divert it once inside.
twelvepole
twelvepole
