Basement Flooring
Old 11-25-01, 07:39 AM
Received 1 Upvote on 1 Post
Wewalt, post your question again as a reply to this post.
Old 11-27-01, 06:22 AM
Guest
Basement Flooring
We have just purchased a newly built house with an unfinished basement. The concrete finish is the worst scree I have ever seen, it is not level anywhere and has divits and high spots of
1-1/2".
What is my best option to level and prepare the floor for wall to wall carpet? Is ther some type of concrete finish I can use, or should I use wood of some sort with many shims?
I may have enough room to use 2X2 as firring but I question wether a 2X2 is enough support?
Old 11-27-01, 05:58 PM
T
Leveling concrete floor carpet
Check at your local floor covering or home center for some self-leveling compound to level out your concrete floor in preparation for carpet.
Old 12-01-01, 07:15 AM
Twelvepole is right. Use a floor leveler. Very common process. It comes in 5 gallon buckets. Follow the instructions. Good Luck
