Attic addition
Old 12-19-01, 08:51 AM
Guest
Question Attic addition
Is it possible to make your attic space into a room if there is boards criss crossing your attic. I thought I had read somewhere if you attic looks like that then forget it. Is this true?
Old 12-20-01, 08:18 AM
R
The roof structure is apparently supported with trusses. You cannot cut trusses, therefore you cannot finish the attic. There is only one way you could finish it. Have a structural engineer come in and reconfigure the trusses so that space can be provided for the finishing of the attic. Very expensive.
