Inside Concrete Walls
Old 01-20-02, 11:05 PM
Scott Duncan
Question Inside Concrete Walls
Part of my basement that I want to finish has a concrete formed wall which is an inside wall.
I dont really want to have to stud this wall, as I figure it does not require insulation. I havent really planned on eating up 4" in wall thickness either.
2 questions: 1/ Do I NOT need to insulate this wall ?
2/ Is there a good method of attaching drywall to this wall for finishing ie ramset, Tapcons etc.
Any help would be appreciated.
thanks
Scott
Old 01-21-02, 06:29 PM
Torch
Scott,
No, you don't have to insulate the wall.
Regarding attaching drywall to the wall-
You don't say how flat the wall is, but I suspect that if you attach drywall directly to the wall, you will be unhappy with the results. I would attach firing strips to the wall if it seems flat. If the wall is irregular, frame it with 2X4s. In the big picture 4 inches really isn't that big of a deal.
Using a ramset will destroy the drywall and still not secure it. Tapcons may work, but using 1 Tapcon every 12-16 inches is a bit expensive. The cheapest, easiest solution is a ramset with 1X3s and attaching drywall to the wood.
Good luck,
Torch
Old 01-29-02, 04:34 PM
B
if you have cold winters, then insulate
If you have cold winters (2-3 months of temps lower than mid-30s), then insulate!!!!
My insulation paid for itself in 2 years. I have the before and after heating bills to prove it.
Ask any energy auditor. The biggest single thing you can do is insulate the basement walls.
Old 02-06-02, 05:59 PM
Torch
BobF-
I would agree that you should ALWAYS insulate exterior basement walls. But I would not bother insulating the interior concrete walls. Wouldn't you agree??
Torch
Old 02-07-02, 03:52 AM
B
Torch - you're right....
I should have slowed down that day. I read the post to fast and missed the "inside" description.
