basement flooring - wood/concrete, etc
Old 02-19-02, 08:56 AM
L
Here is my dilemma.
I have a basement with a concrete base. the entire floor was covered in wood subflooring, with many layers of linoleum, and carpet. I recently demo'd the kitchen and layed a 2nd layer of concrete to even out the base, then tiled it. although i think this is ultimately the best method, it took me an entire day, 40 bags of concrete and a sore back to get it done. it is much cleaner as a result, but now, in the winter months, the floor does get quite cold.
as i began demo'ing the remainder of the basement, a portion of the wood subfloor (same floor as in kitchen, even more layers of linoleum..) was rotted away, so i tore it out. as time is an issue here, and the cost for a contractor to concrete the space is out of budget, I will install a new wood subfloor to match existing, and recarpet. the current subfloor is approx 6" off the concrete base.
(this will all result in a sunken-in kitchen, about 6" lower than the remainder of the apt. i can live with this, i think!)
my question - a lot of dirt, etc accumated in the floor under the wood, and im sure into my carpets over the years. is there a type of insulation that can be used in between the wood subfloor and the carpet/padding? its too late to get anything under the wood, i dont want to tear it all up just to re-lay it. what can i use?
#2 - regarding walls and framing, ive installed new framing, with styrofoam type insulation in between joists, duct taped onto the wood just to seal it a bit more. (i did actually feel a diff here!)
Is a vapor barrier necessary between the framing and the drywall? there has never been leaking into the walls from the block foundation.
thx!
Old 02-21-02, 12:24 PM
L
?? anyone??
