Framing but stuck, can you help????
Old 02-21-02, 09:42 AM
jmk208
Angry Framing but stuck, can you help????
I am going to begin framing my basement. Around the floor is uneven cement from when french drains were put in. I will use pressure treated wood for the floor since it is code. How do I get the wood flat and level. Can I use shims? they are not pressure treated and will rot. Do I recement it (I hope not). Any ideas?
Old 02-23-02, 03:13 AM
A
Use cedar shims and treat them with a wolmanizing end cut solution. Lay down a poly moisture barrier on top of the concrete before framing the floor.
