Vapor Barrier - huh?
OK - I decided to NOT drylock and go with a vapor barrier. But I have no read from different sources that there is some debate as to where the 6mm poly should go.
If I am going to build my walls with insulation a few inches out from the poured concrete - should the vapor barrier go:
a- against the concrete
b- against the back of the wall - facing the concrete
c- on the inside of the wall facing the room (and just behind the drywall)
Also- can I just use a staple gun to attach it with some tape in the right places?
Thank you again!
(PS - If I use faced insulation - is it faced on both sides? If not - which face should face the concrete - the covered, or uncovered?)
Thank you again!
Recently Building Codes in many states have made a change, and now require 6ml on both sides of the wall. In other words after insulating, you then cover the inside of the wall again before the sheetrock or paneling. I have done this practice for years.
