foundation
Old 05-16-02, 06:57 AM
quantel62
Question foundation
Hey everyone....need a little help here.
I will be building a new home and I know this sounds like a dumb questions, but I need to know and don't know.
Anyways, I will be having to do a step foundation as the front of the basement will be fully exposed (having a walk out).
What is the normal size of a foundation?
Since I am doing a step foundation, should I be putting styofoam insulation from the foundation out two feet to prevent the frost from getting under the foundation?
If so, how far down should I be putting the insulation?
How far around the corners should I go with the insulation?
Is this insulation really needed?
Any help would be greatly appreciated.
Old 05-18-02, 04:25 PM
T
Received 1 Vote on 1 Post
Basement insulation
For expert insulation information, go to http://www.resercon.com/
Size and types of foundations must meet local building codes. You need to check in with your local authorities regarding codes, permits, and inspections before beginning your project.
For foundation information, click the following links:
http://www.hometips.com/hyhw/structure/106found.html
http://www.askbuild.com/cgi-bin/column?046
http://www.atlasblock.com/residentia...tm#six_reasons
http://www.howstuffworks.com/house4.htm
