furance/ water heater frame clearance
Old 05-27-02, 06:17 AM
Could someone please post the requirements for minimum clearances of framing to enclose a furnace and water heater with regards to access and service area and door size and style.
Thank You
Stephen
Old 05-27-02, 07:17 AM
T
Received 1 Upvote on 1 Post
Framing clearances for furnance and hot water heater
Local building codes tend to dictate these clearances, ventilation and other requirements. You will need to check in with local authorities regarding permits, codes, and inspections.
Most tend to require that you provide the locations of your furnace, hot water heater, and chimney. Indicate the type of furnace, hot water heater, and chimney type as well as the service side of the furnace. Refer to the manufacturer's specifications for exact guidelines, these dimensions shall be required at the time of submission for the permit.
http://www.doityourself.com/architec...ingpermits.htm
Old 05-27-02, 04:55 PM
See this thread from one week ago on the same subject.
