do I really need to waterproof
Old 06-07-02, 08:09 AM
tdanner1
I have a three level split..so technically the first level is not a basement. However, the first level has cinderblock walls and we do run a dehumidifyer. I am replacing the panelling and also the glued on carpet with new panelling and tile. I can use drylock on the floor- no problem. But in order to use it on the cinderblock walls, I would need to remove all of the furring strips and then replace them. How important is this since this level is mostly above ground? Thanks for any advice.
Old 06-07-02, 06:09 PM
bungalow jeff
Not very since any coating inside a wall is not waterproofing, but expensive paint.
Old 06-16-02, 08:48 PM
T
Received 1 Upvote on 1 Post
Basement moisture problems
You can prevent most basement moisture problems:
http://www.extension.umn.edu/distrib...s/7051-03.html
The research does not tend to show that basement waterproofing coatings are "expensive paint." While coatings/sealers will not resolve moisture problems, they will reduce vapor transmissions in masonry walls and floors.
