Framing / windows
Old 07-03-02, 06:38 AM
G
New Member
Framing / windows
Hi,
I'm planning the framing of my basement and I need some advice. My exterior walls have two levels, with the lower level ( cinder blocks ) extended about 4 inches further than the rest so I have two options : frame out a lower level and create a ledge or simply create a wall beginning at the lower level. If I create the one wall then the window will be about 1.5' away from the drywall.
Any advice or photos would be greatly appreciated.
If you want to send them directly to me my email is
ph517@yahoo.com
Thanks
Old 07-03-02, 03:02 PM
Received 1 Upvote on 1 Post
Either way will work. It depends on what you think will look and work best for you. A deep setback for the window can easily be framed if you choose that route. Personally, I'd probably go with the ledge idea. It will give you a place to set your beer no matter where you are, and/or you can use it for other items (e.g., the TV remote, books, pool table chalk). It will also make the room look a little larger. You can either do a painted pine ledge, or go fancy with a nice stained oak ledge.
