squeakie bicycle wheel
Old 10-29-02, 04:26 PM
Lordjack
Angry squeakie bicycle wheel
My front bicycle wheel sqeaks when there is no load on it but when i'm on The bike it don't make the noise ?
Old 11-06-02, 04:14 PM
George's Avatar
Check the adjustment of the bearing cones - and lubricate according to the mafg's specs.
Old 04-22-03, 07:07 PM
engine ear
oil
just give it some oil and you should be fine
Old 04-24-03, 07:58 PM
Precision Pedal
Sounds like the bearings could use to be pulled out cleaned and the hubs races cleaned as well. Hubs on a bicycle require grease not oil, and DO NOT use automotive grease! Any LBS should have some type of waterproof grease suitable for this job. The key is to get the hub comnes properly adjusted so that they are not to tight or too loose. More info can be found here:
http://www.sheldonbrown.com/cone-adjustment.html
