Adult coaster brake single speed
Old 07-20-03, 05:39 PM
las
Does anybody got a couple 22t cogs for the gear...so I can gear me bicycle down a bit,some say that the 20t is the biggest but I've heard that a 22t might be biggest,I've tried many people even Nashbar NOTHING,I'm trying to lower the gearing somewhat?
Old 07-21-03, 05:24 AM
CampyGuy
gearing
what gear do you have in front? often with single speed bikes it's easier to just use a smaller chinring than try and fing a larger freewheel.
webcyclery has ENO freewheels in up to a 23, but they run about $80, probably better to just go smaller in front, you could probably go as low as a 34 for under $20.
Old 07-21-03, 12:08 PM
las
I don't mean freewheel...coaster brake
It's not a freewheel...the cog that you use on a coaster brake bicycle is not identified has a freewheel?I already have the 20t one but I see on the bicycle forums that there might be a 22t out there somewhere?I would be willing to buy a couple of those I've tried every where Nashbar,other cycle shops nothing..I mean in the 22t variety
Old 07-22-03, 04:04 AM
CampyGuy
i think i misunderstood, didn't realize it wasn't a freewheel.
maybe check out sheldonbrown.com, and aebike.com (or any other online sotre that has the QBP catalog).
good luck
Old 07-22-03, 06:36 AM
Precision Pedal
Depends on the hub. Shimano hubs have cogs available up to 21 and others have cogs available upto 22. Most local bike shops should nbe able to order these for you if they do not have them in stock.
Old 07-29-03, 12:22 PM
jcmjrt
You might want to try The Third Hand. They have tools and parts and might be able to help you.
