Handlebar adjustment
Old 07-16-00, 09:04 AM
Guest
Question
Help! I can't raise the handlebars on my sons bike.
Old 07-24-00, 06:02 AM
Guest
Post
there should be an allen head screw on the top of the bas set. Loosen it and you should be able to raise and lower. If not, then let me know what type of bike.
Old 07-25-00, 03:54 PM
Guest
Post
I believe that the allen wrench is a 6 mm. Loosen it and then tap it downward to loosen the bars in the head tube/head set assembly.
Be careful not to loosen it too far or the wedge will fall off the end of the bolt.
Raise it to the appropriate height and do not raise it above the suggested height marking. The message says something like "Caution: do raise above this line"
More than a Carpenter
http://www.carpenter.cjb.net
