Go Back  DoItYourself.com Community Forums > Recreational Outdoor Activities > Biking and Bicycles
Reload this Page >
Rear disk pressed against caliper with no apparent adjustment available
Old 09-13-21, 03:58 PM
This is my Cannondale bent 2. Never had this problem that I've noticed and have been riding this bike for a long time. I can't see what happened to have had this result nor can I see any thing to adjust. Any ideas? Otherwise I'm thinking I just need to find a washer to put on the axle there to push the caliper out a bit. Thanks!
Old 09-13-21, 08:48 PM
Received 3,422 Upvotes on 3,068 Posts
Usually the calipers float (slide) and center automatically over the rotor.
Possibly the caliper is frozen and won't slide.
Old 09-14-21, 02:51 AM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
My bike has an adjustment screw for one pad but it looks like your wheel has been installed crooked so that the disc is not centered in the gap between the pads.
Old 09-14-21, 11:55 AM
I agree. It looks like if you loosen the axle bolt on that side you can slide the hub further into the fork. That will center the disk in the brake hub.
Old 09-15-21, 12:19 PM
F
Received 48 Upvotes on 37 Posts
Here's a page (on Park Tool's website) on how to adjust an Avid cable-actuated disc brake. There might be differences (both pads move in some cable discs but only one pad in others) but it should get you headed in the right direction.
EDIT:
Here's a link to the mfgr's manual with details on how to adjust the Bb7 model or the Bb5 (which apparently are different).
Old 10-05-21, 11:10 AM
Well there was no way to adjust anything I could find. The alignment is just off for some reason and the axle can't fit into the fork any other way but right in it. So I just threw in a spacer about a mm thick and it did the trick
How did that red arrow get inserted into my original Pic BTW lol?
Old 10-05-21, 01:30 PM
I'm listed in that post as modifying it.
That's where I explained the the axle can be slid in and out of a slot to center the brake hub.
