Cutting Headrail
Cutting Headrail
The headrail on my vertical blinds is too long. They extend past my window by 2 vanes on each side. Is there any way to cut the headrail. By the way... they are center split. Thank you in advance.
I assume that this is mounted on the outside of the window frame? If so, when I measure Verticals, I always make them extend beyond the window so that you get better coverage. If you must cut the track...........don't since you may create problems.
