Roller Blind Won't Stay Up
Old 02-18-04, 04:10 PM
applause4you
Unhappy Roller Blind Won't Stay Up
Hello --
I can't get one of my roller blinds to roll up. I've rolled and unrolled it, and wound the spring end. When I hang it in the window, it just feeds the blind all the way out. Any suggestions?
Deborah
Old 02-18-04, 05:03 PM
Dave_D1945's Avatar
When you wound the spring end, did the ratchetting mechanism work? If not, shoot a spritz of WD-40 into it. They sometimes stick and won't engage.
Old 02-18-04, 05:15 PM
applause4you
Roller Blind
Yes, the spring end winds if that is what you mean.
Old 02-18-04, 05:26 PM
Dave_D1945's Avatar
When you stop winding it, does it stay wound or spin back open? If it spins back open, the ratchet isn't engaging. It may be stuck or worn out. I use the WD-40 when they stick and they work fine after that.
Old 02-18-04, 05:30 PM
applause4you
Roller Blind
It stays put unless wound too far. It's a fairly new shade. Nevertheless it does not allow the shade to be rewound.
Old 02-18-04, 05:51 PM
Dave_D1945's Avatar
Might be best to take it back to where you bought it. Those ratchetting mechanisms are pretty cheaply made and yours migh be defective.
Old 02-19-04, 04:41 PM
johnam's Avatar
Received 8 Votes on 8 Posts
If you used the existing brackets, check the bracket at the spring end, the slot is probably worn or spread out. Replace the brackets.
Old 02-19-04, 04:59 PM
applause4you
Roller Blinds
Yes, it turned out to be the brackets after all. I tried another blind and it also would not stay up!
