Evil Cat wrecked mini blinds
My cat has broken off 4 of my mini blinds ends, but in the centre of the blinds. Does anybody know how to remove the bottom piece, to access the extra strips that are always included?? Also do you know how to put the new strips on?
Thanks, Tadaaa
Thanks, Tadaaa
you can probably go the manufacturer's website and find directions.
i've removed extra slats when they've been too long, but haven't replaced damaged ones. if you'll look on the underside of the bottom rail, there should be a couple buttons (plugs). pry them off and you'll see the extra cord is stuffed in there. when shortening blinds, i would cut the strings up to the last one i want left, and then replace the bottom rail and plug it back up. i don't know how you'd re-string the new slats. that's where the website instructions will help you!!! (unless someone else speaks up!!)
good luck!
good luck!
