Curling pull shades
Curling pull shades
I have tried several weights of vinyl pull shades on my home windows and all seem to curl in along the vertical edges - and not just a little bit, a lot. They curl in enough that the privacy one would normally expect is impared. A couple of questions to the forum.
1. Is this the nature of vinyl pull shades?
2. Does anyone manufacture a roll-up pull shade which does not curl?
Tnx for any insight.
Mho
Mho
This is not the nature of roller shades and I can't say I've encountered that problem before. Usually curling happens when something is too tight or off kilter. Are you buying the correct size? Are you rolling it too tight or crooked? Or perhaps the place that's cutting it for you is cutting it off grain or using a cutter with a dull knife. Maybe someone else has better thoughts on this, but these things come to mind. If they're all the same brand then maybe try a different brand, but sorry I don't know of any to recommend.
I've installed shades for 40 years. It's the nature of vinyl shades to curl. Some have a tendency to curl more than others. If they were left to hang, the curl will lessen but when you roll them up and pull them down again the curl returns. Good quality fiberglass shades curl less.
I agree with the experiences that johnam has stated, and that other shade materials will hang better.
I kinda suspect the direct pulling of the shade itself from the bottom rail or tassel may contribute to this curling. Especially if the spring tension is set too high. In fact, most roller shades I do now come standard with a beaded chain loop that is used to raise and lower the shade. This eliminates pulling directly on the shade now, and offers 100% control over shade open/close position. This may be something you could consider.
