Vertical blind trouble
Old 06-02-14, 12:45 AM
C
I have a set of vertical blinds that rotate fine to let light in the problem is when I am shutting them the first 5 go all the way to the end, then the next 5 do not move, if I push manually at the top those 5 will close along with the next 10 so the middle 5 will not close unless done manually when I push then they all go, is thre any way to fix this without having to replace everything??? Any help would be greatly appreciated I do not want to have to pay to replace
Old 06-03-14, 04:27 AM
johnam's Avatar
Received 7 Votes on 7 Posts
Look inside the track, each vane carrier should be linked to each other. Look at the 5th vane and you should find that the link is detached or broken. If it's broken you will have to get one from the manufacturer of the blind. It's not an easy repair.
