Filling the gap between wall and Vertical Blind head rail.
Old 09-23-14, 08:39 PM
T
Hello,
My first project of installing the blinds is not going well.
I took wall to wall measurement and went to Home Depot and got the Home Decor premium Faux wood blinds.
After coming home I realized that the vertical measurement wasn't accurate as there is a half inch tile that starts 15 inches from the top.
I went and got the blinds cut.
Now I noticed that the Head rail is too short and not secured well as shown in the pics.
I would really appreciate if you could give me an idea how to fill the gap between the wall and the head rail.
Thanks in advance.
Old 09-23-14, 09:09 PM
XSleeper's Avatar
Received 773 Votes on 714 Posts
Looks like you need to take the blinds down, take your end caps off, and move them in 1/2" on each side.
Old 09-24-14, 04:09 AM
Received 359 Votes on 316 Posts
to elaborate, a small block of plywood between the bracket and the wall will close up the gap.
Old 09-24-14, 04:19 AM
czizzi's Avatar
Received 14 Votes on 12 Posts
Blind brackets have the option of being screwed into the side of the window frame or screwed into the header of the window frame. Unscrew the brackets, and re-attach at the correct width by screwing them into the header of the window.
Old 09-24-14, 10:33 AM
Shadeladie's Avatar
Super Moderator
Received 141 Votes on 110 Posts
Those are horizontal blinds, not vertical blinds.
