roller blind wont go back up
Old 11-23-14, 11:51 PM
L
i pulled blind down to discover it wont pull back up help please
Old 11-24-14, 03:24 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
Take blind down and see it you car retention spring. Turn the end with spring, you will see it lock every turn. Spring may have broken.
Old 11-24-14, 08:51 AM
Shadeladie's Avatar
Super Moderator
Received 141 Votes on 110 Posts
First, check to see if it's just a tension problem. Try pulling it all the way out, then (after taking it out of the brackets) reroll it by hand and see if it goes up.
You didn't give enough info, to let us know the correct advice to give you.
