Our PowerRise blinds started having problems going up and down. The motor started making loud squealing noises when moving. It seemed like the motor or gears were binding-up. I finally ended up taking the blinds apart, removing the motor, getting the motor specs and ordering a new motor from Ebay. The replacement motor fit perfectly. After re-assembling, it worked just like new...any much quieter.
The motor spec is: Copal DC Gear Motor LA16G-324SH, 50:1 300RPM, 12V (4.8-14.8V).
Also, years previously, the blinds weren't working, even after replacing the batteries. I found that the far end of the tube where the batteries are stacked was dirty and not making electrical contact. I put some steel wool on the end of w wooded dowel and stuck down the tube and after turning around and around many times and reinserting the batteries, things worked again...
I posted the info as an FYI because I couldn't find any helps from the internet searches I did when I encountered the problem. I wanted to post the solution in case someone else had the same issue with the blind's motor.
Great!! Thank you!
And on the other side of the base, Do I have to separate the plastic tube?
By chance do you know which remote control model pairs with this motor base?
I'm having same problem with my hunter Douglas power rise shades and need to buy replacement motors (copal motor la16g-324sh). Can you please provide the link where you bought these at?
Thanks,
Brad
BradKan,
It looks like the exact motor that I used was discontinued, but it looks like this one is very close to the original and looks like it would work just fine...The specs are almost identical. Robot MarketPlace - COPAL 50:1 Gearmotor - 12VDC
That's great. Thank you both for your helpful replies. I will investigate the alternative motor since it looks like the original one has been discontinued.
I'm trying to replace my dc motor made by Copal
Part Number LA 16G-324SH 50:1 300RPM in my
Duette power rise system.. Does anyone know
where to purchase one. I believe that the original
manufacturer does not make the part any longer.
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/768x1024/274676231_1163765144168159_4582429677501600478_n_ace8057bccd87dfa1d67a8d51384bb1ea8263a39.jpg[/img]
How can I go about fixing this?
