Vertical blind bracket
Received 0 Votes
I'm trying to fix the bead stop on my blinds as it's no longer aligned and the blinds can't go up all the way.
The problem I'm facing is that there's a bracket covering the edges of the roller and I can't figure out how to remove it. Please help!
https://imgur.com/a/y2Z4064
Usually the blind clips into the bracket but each manufacturer seems to do theirs a bit differently. You may have to lift up on that end of the bracket while pushing the blind away from the bracket.
