Shade repair
Old 09-05-20, 11:13 AM
I
Received 3 Upvotes on 3 Posts
Shade repair
My cordless shade is broken. There are two separate shades mounted on one mount, each shade a little over 3 feet wide and 8 feet long, for a sliding door. One shade looks puckered on the top/left side, makes a clicking noise when raised or lowered, and won't go all the way up. I've done the "gently pull the shade all the way down, gently pull on one side then the other, raise the shade back up" trick, but that does nothing.
The only markings are Gloria 2T 19963.....Cellular Shade C#: 82CPCS0212.04
FCH EV 02/12/15 CLASS R.
Is this a DIY project?
I took it down to look at the inner workings, but nothing looked obviously wrong, not that I would really know what to look for.
Any suggestions.
Old 09-05-20, 02:41 PM
P
Received 1,849 Upvotes on 1,655 Posts
Power and operate the shade now that you have it down and watch it while it's moving. I'm thinking something is binding or the plastic holding a shaft, motor or gear is cracked allowing them to move and the gears skip when under load.
Old 09-06-20, 07:10 AM
I
Thanks, I will try that, it's not a power shade, it's manual, but I can still pull it up and down and look at what happens.
Old 04-20-21, 04:33 AM
KirbyK's Avatar
Received 1 Upvote on 1 Post
Blinds are a really tricky fix if you don't know what you're doing. I tried to fix a bedroom blind recently and couldn't get it just right.
Eventually brought it into a local shop and he repaired it for €20. Couldn't believe how reasonable the fix was.
If you don't get it yourself, it might just be worth bringing it into someone.
