vertical blinds
vertical blinds
Am i able to fix my vertical blind ?
When closing the left side closes and slides to the centre but the right side only one panel moves to the centre the rest stay to one side .
Thank you
Thank you
Whether or not you can fix it depends on your skills and the tools you have available. Have you taken the blind down and looked into the track to see what is broken or not working?
Look inside the track. Each panel is connected with a carrier spacer. It seems to me that the one that's moving on the right is disconnected from the next panel or the connector is broken. This an example of the part, every manufacturer is different.
