Blind hard to pull down
Old 11-22-22, 07:45 AM
I
Received 4 Upvotes on 4 Posts
Bali blind about 5 years old. Cordless honeycomb cellular, pulls down from top and raise up from bottom. BL 1295 TQTY. It works okay, it's not uneven, it goes up and down okay. But doesn't pull down easily. It takes some effort to pull it down. Should I be concerned, can I adjust the tension?
Old 11-22-22, 09:00 AM
P
Received 2,224 Upvotes on 1,985 Posts
Yes, you should be concerned. No you cannot generally adjust the tension. You just need to look closely at the blind and figure out why it's harder now. Is a cord wrapped around something? Has a chunk of dirt bound something up? Is there a gear or other plastic bit breaking apart? I move the blind slowly while feeling and looking. I also look at what is moving and how. I start at the cord. Look at where the cord goes in the mechanism. Then follow it through any pulleys or gears looking for something not right.
izzie voted this post useful.
Old 11-22-22, 09:27 AM
I
Thanks, I'm getting fed up with blinds. Had a different blind break a year go, I replaced it with curtains on a cafe rod. . Blinds are so expensive. I will "fiddle" with it, I'm not optimistic.
Old 11-22-22, 10:12 AM
P
Blinds, and it doesn't matter what brand, are problematic because of their complex nature and inexpensive construction. They have pull cords, pulleys, gears, sliding tracks... and many parts are plastic that age and get brittle with time whether you use them or not. It all adds up to potential problems.
Don't forget to search if you need parts. There are several online retailers that sell replacement parts for Bali blinds. You can check out this company for example. I have never purchased from them but hopefully you can find the parts you need.
Old 11-22-22, 10:36 AM
Shadeladie's Avatar
Super Moderator
Received 398 Upvotes on 326 Posts
If they're custom, they may still be under warranty. To fix it yourself, you'll probably have to take it apart to replace whatever is broken. May be easier to send it out for repair, but depending on how much you paid for the blind, might be cheaper to just buy a new one.
