composite shutter repair
Old 04-10-23, 08:59 AM
I have some shutters which are composite and the sides are made of plastic.
This is where the slats fit in. Since they are made of plastic they tend to break easily.
Is there any way to replace these.?
inside of the side
outside of the side
the plastic side which has holes drilled into
Old 04-10-23, 09:14 AM
P
Received 1,950 Upvotes on 1,746 Posts
Buy new shutters. Once the plastic is brittle and fragile like that it just continues to get worse.
Old 04-10-23, 02:54 PM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Have you reached out to the manufacturer for replacements?
Old 04-11-23, 05:54 AM
B
Received 258 Upvotes on 230 Posts
Because most of the side channel damage is around pivot holes, my guess is the blind material is expanding when warming (pivot holes getting smaller, slat axles getting bigger) resulting in rotation interference. Replace side channels with wood trim drilled with holes located from the plastic side channels.
jack brown voted this post useful.
Old 04-11-23, 06:26 AM
The side channel is getting damaged because of impact from pets or furniture but not because of weather related expansion/contraction.
The manufacturere is not responding any more
Old 04-11-23, 09:03 AM
Marq1's Avatar
It's difficult to tell from pictures provided but if this was mine, and I know how expensive plantation shutters cost, I would be looking to try and fabricate those side pieces, maybe with strips of wood cut & drilled to fit where the plastic parts go.
