blind
Old 10-20-01, 05:45 PM
Guest
I have vertical blinds and when I close them a couple of them don't rotate to the proper position. Can anyone tell me how to repair them?
Thanks for any help.
Sorie
Old 10-21-01, 08:10 AM
johnam's Avatar
Received 7 Votes on 7 Posts
If your track is the self-clutching type try pulling the chains beyond where you normally stop. Do this in both directions. You will hear a ratching sound and the vanes should go back in sync.
The other type tracks sometimes require that you hold the carrier that is out of sync while you rotate the others with the chain until it lines up with the other carriers.
If the carrier gears are broken nothing can be done.
