thermostat
Old 02-10-04, 06:43 PM
mason123
thermostat
how come my thermostat gets hotter than the temp that i set it for
Old 02-10-04, 08:10 PM
KField's Avatar
Sounds like overshoot. There is possibly a small heat anticipator setting inside the thermostat. You might be able to adjust it for a shorter run. What is the brand and style of thermostat? Is it digital?
Old 02-11-04, 07:35 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Like ken said pull the cover off the tstat and look. You should see a dial like with a pointer on it push it to shorter. Just a little bit then let it run for a day and see. If it still over runs do it some more. ED
