automatic water feed
Old 02-18-04, 01:59 PM
roberthelfrick
I have an automatic water feeder on my gas/steam system. Suddenly the water level permitted is higher-to the top of the glass-causing water hammering. How can the level be adyusted downward?
Old 02-19-04, 11:10 AM
Ed Imeduc's Avatar
Take and make sure the float is clear and no yuck is around it or blocks it there should be clecn out plugs on it. ED
Old 02-19-04, 07:05 PM
H
Received 1 Vote on 1 Post
the low water cut off
the big black ball looking thing is the low water cut-off... if you had a good plumber, he left you a flush valve on the bottom side of it. You need to flush about a quart every week or so into a 5 gallon bucket... leave it there and empty it when its half full...if you want , you can adjust the level with that device.
Old 02-19-04, 07:14 PM
imjerry
I Agree
Mucked up balls very often are the problem, However the valve seats on many McDonnel Millers get worn and dont close off tight, so both can cause boiler flooding!!! If flushing the Feeder doesn't work, I would check the valve parts, depending on the model some have needle and seat others have plunger and seat.
Kits are availablre to rebuild them, and new float ball are also available if the ball float has leaked and is full of water!!
Good Luck Jerry
