hot water baseboard water hammer
Old 02-28-04, 09:06 PM
Cloveroad
My house is 2 1/2 years old. We have hot water baseboard heat. When the furnace
shuts off there is a water hammer type sound......but not every time. The pipes
that hammer are in the floor of the second story. What are the options to deal with this. Thanks
Old 02-29-04, 08:15 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Info info would help here . Whats the psi and temp on the boiler. The noise , when the burner shuts off or the pump ??? Did you bleed all the upstairs baseboard??? Is the expansion tank ok???? ED
Old 02-29-04, 01:14 PM
Hellrazor's Avatar
Most likely its air in the pipes. You will need to bleed the system.
Old 02-29-04, 06:17 PM
KField's Avatar
Check the zone valves to be sure they are installed in the correct direction. There will be an arrow on the body. Be sure it points in the direction of water flow. If it does not, you have located your noise.
