Oil Heater leaking water
Old 04-11-04, 07:02 PM
wheelhorse
Hello,
I have an oil burner which heats my home. I just noticed that there is water leaking from the unit when it is running. I removed the side panel of the burner and noticed that after about a minute of operation one area of heater (I guess it's cast iron) starts to leak from perhaps a hairline crack.
Is it time for a new heater or can this be repaired/patched?
Thank You
Old 04-12-04, 08:02 AM
mattison's Avatar
Best to get a hands on look at this. If it's a crack I doubt it will get fixed unless it's a replaceable part and is feasable to replace it. How old is the boiler?
Old 04-12-04, 08:22 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
With Matt here :You dont say for sure just what you have here or how old it is or just what kind it is.
I think you should get 3 bids for work on it or a new boiler. Some one has to look at it to say what can be done.
ED
Old 04-13-04, 05:30 AM
wheelhorse
The burner is a Burnham and is 7 years old (as old as the house). The service guy said that the 'block' is cracked and needs to be replaced, as I suspected. The part should be under warranty, but it looks like we have to pay for the labor.
This sounds like something a licensed plumber needs to fix. Any idea how intense a job this is?...manhours?
Thanks
Old 04-15-04, 08:06 PM
KField's Avatar
2 men, 2 hours each and one man for 4 more should be adequate for replacement of the boiler block.
