No Hot Water
Old 05-03-04, 09:28 AM
Firbank
No Hot Water
My daughter's house has been unoccupied for 9 months although the central heating has been on for a couple of hours each day during winter to avoid bursts. Now the water from the hot tap is running cold. The central heating works OK. I've tried the thermostat at both 1) for Hot water only and 2) for Heating and Hot water but with no success. Any suggestions please.
Old 05-03-04, 10:10 AM
Ed Imeduc's Avatar
Wink
It will help a lot here if we know just what you have for heat and hot water . If its a boiler does it run all the time now???Do you have a water coil in it for hot water . Need info info and then some one can help you here.
ED
