Boiler Water Feed Check Valve Failure -
Old 08-04-04, 12:50 PM
sdanville's Avatar
I have an apartment building.
Last year the city had me install some $100 vented dual check valve that would prevent the boiler water from reversing to the hot water heater. The $3 check valve wasnt good enough. So my tenant called today at 7 AM about a water noise. The valve switched today to send the water out the valve to the drain. My furnace has been off for a month or more as it is summer. I tapped the valve with a hammer a couple times...shut the water on and off a couple times...but had to leave it shut off or it directoly goes down the drain. How does one reset it? And why/how did it fail ? thanks in advance. sdanville@grar.com
Old 08-06-04, 04:52 PM
KField's Avatar
There is probably a rebuild kit available for the valve. Or you could just disassemble it and clean the parts. It is probably only a piece of dirt causing the problem.
Ken
Old 08-15-04, 06:50 AM
sdanville's Avatar
My Walls dual valve has a torn diaphram
I took it all apart....
$78 valve// lasted a year..shot over a flimsy diaphram.
so far searching the WWW no luck on a diaphram replacement kit.
WATTS 9D 1/2 "
Old 08-15-04, 06:44 PM
Homer Simpson
Failed Check valve
Well, make and model number would help.
Some jurisdictions require one type of valve others a more complicated
valve. Yours could be a double check w/ atmospheric vent, a reduced
pressure backflow preventer or another. It should have lasted longer,
may have been defective. The warranty on the big named ones is a
year from the date of manufacture not installation. So you always want
to install a fresh one and not one that has been sitting on the shelf for
9 mo. . Contact the manufacturer for a kit. But to replace the kit the
jurisdiction wants it retested if it is the kind that can be. A certified
tester is required. You can check Johnstone or Granger for a new one or
your local plumbing company. I have had several reduced pressure backflow
preventers, which is required in my county, leak out of the port and I don't mess with them, I take it back and get a new one that doesn't leak. Sorry,
but I see anything that specifically created this other than a manufacturing
defect. Say goodbye, Homer. Goodbye
Old 08-15-04, 06:51 PM
sdanville's Avatar
makes since what you said.
thanks...
UPDATE --- GOOD OL EBAY> I BOUGHT TWO yes TWO valves for $40.00
about 20% of retail.
