What are my options for bad hot water coil?
Old 10-16-04, 05:29 AM
clinty1
Hello, 1st time user of the forum so I appreciate any info regarding my situation.
I have a HB Smith boiler and the hot water coil seems to have a buildup within it. I have heard you can get them acid-flushed or install a new coil. I called the plumbing shop and they said a coil would be about $180. I looked at my boiler and it looks real clean, all the bolts and surfaces are very clean. I can't see any corrosion, rust, etc. I have heard these are a real pain to change and you never know what you are going to be getting in to. The HB Smith boiler is a B Series S/W-5, Serial Number: D88 917P (manufactured in 1987) and the coil plate says "Heat Transfer Products" on it. Anybody have any experience changing these out?
Also, I have heard people disconnect the coil and install a seperate heater for hot water. Any tips on this and what would that cost me to do?
Thanks a bunch, Clint
Old 10-16-04, 08:21 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You can acid clean the coil right there in the boiler if you want. Get a bucket some muractic acid. A cheap drill pump and some hose. Take the water lines in and out of the coil off. Mix water and acid in bucket50/50. Put a hose from bucket to drill pump, a hose from pump to water in at the coil. A hose from out of the coil back to the bucket . Turn it on and let it run. Might need more acid in the water as it runs.
ED
Old 10-23-04, 07:17 AM
macrophyllum
As anyone tried this? If so, have you had much luck. My coil is on its way out (hot water pressure is very low), but I am thinking of installing a on-demand electric hot water heater so that I don't need to rely on oil in the summer months. Any comments/suggestions most welcome.
~Ian
Old 10-23-04, 11:33 AM
Ed Imeduc's Avatar
Thumbs up
Have cleaned out many a coil this way "Mac." In boilers water cooled Ac units On boats for the ac coils there and engine cooling coils.
ED
