permanent removal of radiator
Old 10-17-04, 06:47 PM
I have a hot water radiator system. It appears to be a two pipe system (a separate pipe for incoming and outgoing water).
I wish to permanently remove a radiator.
How do I do this?
Old 10-17-04, 07:00 PM
majakdragon's Avatar
You will have to turn off the water and drain down the system. There should be union type connections on the radiator to disconnect it from the piping.Disconnect the fittings and remove the radiator.Unscrew the pipes and then use plugs in the holes where the pipes were removed.Good luck and post back.
