Draining the water system...?
Old 11-08-04, 11:08 AM
jake75
How do you drain the water system? The reason being is that I need to rais my waste pipe from its new position in order to get a downward flow. In order to do this I have to move some piping.
Thanks
Old 11-08-04, 12:41 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Hi Jake,
You might want to repost this question on the plumbing board, as this board deals mainly with steam and hot water boilers and systems.
But I will take a crack at it--
I would start by turning your main water supply off, then opening all the faucets, especially the lowest ones and the hightst ones. This removes the vacuum, allowing the system to drain down properly.
Old 11-08-04, 07:26 PM
A
Received 1 Upvote on 1 Post
Jake,
What water system are you trying to drain?
Old 11-09-04, 06:40 AM
Ed Imeduc's Avatar
Wink
What do you mean? Home water , Sewer or Boiler.
Ed
