Dettson furnace
Old 12-01-04, 01:27 PM
K.Gomes
Post Dettson furnace
Hello,
I have a Dettson furnace with a Reillo F5 burner. All seems to be going good so far. The unit is about 3-4 years old and I have a few questions.
Should I empty the lines and replace the water?
My expansion tank is quite small, and should i empty it?
Any cleaning i could do myself to the furnace?
Thanks,
Old 12-01-04, 01:57 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
let the water as is. I take it this is a oil burner. Now that you should have it serviced each year. Filter, nozzle , checked and cleaned draft and Co2 checked. As long as you have air in that expansion tank its ok. You can work on the burner if you know how. It pays to have it serviced each year in the oil you can save.
ED
