no open close valve on radiator
Old 12-06-04, 06:43 PM
mmd
just bought home and all but one radiator gets very hot when i checked to make sure the valve was open, found that there wasnt one is this normal? if it is, is it ok to bleed it? thank you
Old 12-06-04, 09:30 PM
A
Received 1 Upvote on 1 Post
Not real clear on which valve you are talking about. I assume this is a hot water, not steam system. If so, I'll bet the cold radiator is the one furthest from the boiler. Yes you can bleed it. If that does not resolve the problem, let us know, by hitting the reply button at the bottom, and it will bring your new post back to the top.
