boiler ignites but water doesn't circulate
We had to drain our system to replace a section of baseboard. We have refilled the system. it is has three zones. The boiler ignites but the water doesn't circulate through the system. Can you make a suggestion as to what the problem may be?
Also double check to make sure the circulator pump is running when the boiler is fired. Since you introduced air to the system, Ken's recommendation will most likely solve your problem.
