Leaking Taco Zone Valve
One of my Taco zone valves (gold head) is leaking from what appears to be the gasket from the base unit to the head. Can this be repaired without soldering in a new valve (rebuild kit?). Can I do it without drraining down the system? I have a shutoff valve on the radiator side but not on the ciculator side of the valve.
Any help would sure be appreciated.
Thanks,
Joe
Thanks,
Joe
The only way you will be able to repair it is to cannibalize a brand new valve. The parts you need are not sold individually but if you buy the whole thing and use what you need, you will have a spare power head and save the labor cost of having someone replace the valve for you.
Ken
Ken
Received 0 Votes
leaking taco zone valve
Did you have to drain your system? I have the same exact problem and I bought the zone valve today but I'm trying to avoid draining the entire system. If anyone has any suggestions I'd appreciate it.
Yer gonna have to drain it... you can replace the powerhead without draining, but not the guts.
Look for valves that you can close to isolate as much of the piping as possible and only drain as much as you need to. The less fresh water you introduce to the system, the better.
Received 0 Votes
All done
Thanks NJtrooper:
Drained the system and replaced guts and she's purring like a cat. Anyone know the shelf life of these Taco zone valves?
Mine were installed in 1985 and my feeling is that when one goes get ready to replace the other 8 zone valves.
Most of the valves I have seen fail were because someone overheated them during installation. If that is the case, they may all fain in succession. Maybe just the one you repaired got overheated and the rest will be fine. They seem to last hundreds of years. Exxagerating but longer than my career (30 years).
Ken
Ken
Received 0 Votes
Taco leaking
HI,
My taco is leaking out of the base. I red above post and would like more information. Do you have to sweat a new base on or can you unscrew the four screws on top of the base and replace the inner workings? I can total isolate my valve from the rest of my system.
Thanks, David
Thanks, David
No guarantee
You can probably get away without the soldering if you replace the parts. It is not a normal procedure but the parts have not changed over the years. Take off all water pressure and be careful as there may be spring pressure on the retaining plate. I don't remember.
Ken
Ken
Received 0 Votes
Hey Ken,
Thanks for the quick reply. The taco in question was over heated last Christmas when the bowler make water valve was closed and I lost pressure in the system. My theory is that this zone was open when the loss of pressure and the boiler over heating occurred.
From looking at the schematic of the taco is does look like there is a spring in there being held down potentially by the top plate.
Thanks again, David
Thanks again, David
Received 0 Votes
HI,
I got a new taco zone valve (had to order it b/c around here everybody carries honeywell not taco). I put the new low part in and yes you have to watch out for the spring when you undo the four screws on the base.
Thanks for all the help.
