Therastat vs Actual Heat
Old 01-21-05, 06:26 AM
mb576's Avatar
Red face Therastat vs Actual Heat
I have had this boiler for under a year as well as the thermastat. Its -10 outside. Does this have anything to do with the reading now or is it coincidence their off 10 dg. Thermastat is reading 10dg. at least less than setting and not climbing. Do I need to bleed the lines?
Old 01-21-05, 09:44 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Sounds more like you need more heat. Is the boiler burner running all the time ???????????Are all the baseboards hot? If not what is the temp on the boiler? Most come on at 160o and off at 180o.
Have had to set some up to off at 200o. id check this all out first and post back here.
ED
