New Zone Valve Wiring
Old 01-28-05, 01:18 PM
oiscoot
I have been reading this wiring diagram for the new Taco Zone Valve (3 connection), and I still can't figure it out. Can somebody assist me in wiring this thing in?
Background:
Hot water boiler w\ one zone with no other valves. I installed new zone (2nd zone) and need to wire the valve. Using one circulator and valve is after the circulator. I have a second thermostat to control this valve.
Please Help!
Old 01-28-05, 06:38 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Question Taco Zone Valves
Did you install or do you have an auxillary 24 volt transformer to power the zone valves?
Old 01-31-05, 12:02 PM
oiscoot
I was able to figure it out! I used the 24v transformer within the furnance (dont ask me what kind) and I was able to locate the 24v supply lines with trusty little digimeter!!! I then was able to connect the thermostat (after I reinstalled it the right side up) And all worked wonderful....Now I just have to tie in the circulator!!!
