Thermostat wiring for new system
Old 01-31-05, 01:52 PM
r16s
I just installed an instant on hot water heater for use with a new radiant heat system. Everything is set up and I now need to wire the thermostats. I have 2 zones. For some reason I just have a mental block on figuring this out. Can someone help me. I need to run the wire from each thermostat to it's cooresponding zone valve and then to the pump. Thanks.
- Rick
Old 01-31-05, 02:21 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
r16s
What brand of zone valves & what kind of control fires the burner?
