Hot Water System Queries
Old 02-14-05, 05:56 AM
BLUES MAN
I have just had a ARISTON MICRO COMBI 23/27 MFFI boiler fitted complete with a new set up of water supply. The problem that I now have is that I have very limited hot water supply and it seams very cloudy / airated when used, also when another tap is turned on the supply drops very dramatically. The radiators are not as hot as before (they have been bled).
I don't know if the system has not been installed properly or is just not good enough. Should they have left me with my emersion tank still conected into the system ?. Before I start complaining I would like to hear from anyone who can give me advice on these problems.
Old 02-14-05, 09:56 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
New and just put in. For sure get on them to come back and fix it now while its still cold out. Id check out if it is the same size boiler that you had why it dont work. Id also call the BBB there and find out how good the company is also.
ED
