honey well zone vale
Old 02-14-05, 02:23 PM
joeyjj
honey well zone valve
on zone valve their is manual swith for auto and open ,which is the correct position to leave it on the heat is left on 68 but the room is at 63 no matter how high i raise thermostate raises only 2 degrees , is the motor on the zone valve the promblem?
Old 02-14-05, 05:17 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
joeyjj
An easy way to see if the valve is opening is: While the thermostat is set well above room temperature, you should be able to move the lever on the zone valve almost all the way very easily. If you cannot without feeling spring resistance, the valve is not opening. Further trouble shooting of the valve motor would require the use of a voltmeter to see if you are getting 24 volts to the motor.
