water pump problem
Old 02-16-05, 06:18 AM
tmiu
water pump problem
I have an oil/hot water furnace. Last night the water pump/motor started making a screeching noise. When I went to check, I noticed that there was water laeking from the water pipes. I oiled the motor, thinking this might solve the problem. The noise stopped briefly but then started again. What is the problem? What can I do?
Old 02-16-05, 06:31 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Do you know the name or make of the pump you have there? What color? helps sometimes.
ED
Old 02-16-05, 10:05 AM
tmiu
It`s burgundy. I don`t remember the name (& I`m not there to check it now).
Old 02-16-05, 12:21 PM
A
Its a B&G more than likely and the bearing assembly is probably no good. Sometimes its easier and cheaper to replace the whole thing with a Taco 007 pump.
Old 02-16-05, 01:01 PM
tmiu
Thanks Al. Is that easy to do or should I get a plumber to do it?
Old 02-16-05, 01:44 PM
A
Any heating contractor should be able to do it in less than an hour. If no repiping involved the cost shouldn't be to bad.
